Superswabey
How to hide overhead objects
How to hide overhead objects in archicad? Even when above cut plane it shows. For example, a wardrobe placed overhead overlaps the one below. If I send to back, the lines just thickens and it is not really hidden.
3 Solutions
Lingwisyer
Guru
Unless the object is specifically scripted to, which the default cabinet objects are not, objects will not respond to the Floor Plan Cut Plane. So your option is to hide the ones above in some way. This could be via a seperate Layer, or a Design Option, or but using a unified object so that the top cabinets are part of the same object as the bottom ones.
Ling.
Go to post
Unfortunately objects do not have an option to show/hide relative to the Floor Plan Cut Plane.
You can use layers.
Create a "furniture 2D" layer, "furniture 3D" layer.
Turn the "furniture 2D layer on in plans and the 3D layer off.
Turn them both on for elevations, sections and 3D views.
Turn them both on temporarily in plan while you are working on the file but make sure the plan view has the 3D layer turned off.
Go to post
Lingwisyer
Guru
The constraint is from the shorter door height. It has a range set from 20 to min(doorHeight[1], doorHeight[2]). *facepalm* Who ever wrote the object seems to like using the min command instead of using the actual provided values...
ps. If you care to edit the object yourself, you just need to change the following at line 397 of the Parameter Script:
doorHeight=min (doorHeight[1], doorHeight[2])
to
doorHeight=doorHeight[2]
 The top door does no appear to use this parameter.
Go to post
9 Replies 9
Lingwisyer
Guru
Ling.
Superswabey
If using a unified object, what object can achieve this? I want to use modular wardrobe but it can only have sliding doors.
You can use layers.
Lingwisyer
Guru
Given you have brought up the Modular Wardrobe object, you are not needing the increased door spacings and butt panels forming a cross? Can you just use the segment option in the standard cabinet object to add your top cupboards?
What about the variable wardrobe and adjust the bottom section height and the handle heights.
Superswabey
Hello, I tried this one. I can make the carcass as per the configuration inteded, although i cant seem to raise the door handle higher for the lower doors. Maybe im missing something.
Seems to be a bug in the object.
The lower handle height is constrained - I don't know why.
But, the taller the lower door is, the lower the handle has to be.
Looks like someone got their math calculations mixed up.
Without saving a copy of the object and then editing the script, I don't know any way to change it.
Except turn the handles off and add your own.
Superswabey
Thank you all, I guess the hide layer route is more feasible now.
Lingwisyer
Guru
to
