How to import fill atributes??
I am working in a project that I opened from a dwg file, but my vectorial fills did not loaded when I opened this new file.
How can I import this fills from another project file?
Thanks!
4 REPLIES 4
Options> Element Attributes> Attribute Manager (open the reference file in the right hand side)
Options > Attribute Manager
Click on the fills tab, then on the right size, click Open to open the other file. Select the fills that you want/need and - depending on your need - append or overwrite them into the active file.
AC 29 USA and earlier   •   hardware key   •   macOS Sequoia 15.7.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Snap
Thanks a lot!
