How to join two walls?
Hello
How to join two walls together? I made a spline to one straight wall but i would
like to join them together again how can i make this?
Walls should join automatically as they touch so you need to stretch the end of a wall with the end node until it touches the other wall or trim it with the adjust command (CTRL + - (CTRL and minus) is the default keyboard shortcut).
There are other methods that you might want to look up in the reference guide or have a look at some of the basic tutorials - links are in the HELP menu.
Otherwise post an image of you situation for a more detailed answer.
