How to make COMPLEX SHAPES (ORGANIC FORMS)?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2007-02-07 10:44 PM
is it possible at all?!?
or one has to combine MaxonForm with ArchiCad? can I do it without MaxonForm???
thanx in advance!!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-02-07 11:01 PM
What sort of organic forms are you wanting
to make ?
Peter Devlin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-02-07 11:20 PM
a kind of shape that you can make if you translate a B-spline through the space...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-02-07 11:52 PM
Do a search using the key words "roof mesh" and "hyperbolic paraboloid".
I think you will find some discussions about
forms like what you describe.
Peter Devlin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-02-08 12:01 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-02-08 12:57 PM
Archiforma has 3d lines which you can then loft and create curved surfaces. I'm not an expert user but I've been having some probs in creating curved surfaces with thickness...there must be a way though..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-02-08 04:31 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-02-08 09:11 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-02-08 11:54 PM
Joeri wrote:For furnishings / entourage, this can be a useful method. But, for something that is to be actually built - the shell of a building for example - I don't think that the SU Sandbox tools are sufficient. Happy to be proven wrong though!
Instead of using Maxonform, I model difficult shapes in SketchUP (Sandbox tool) and import in AC as an object. No parametric objects at all, but one get nice results within minutes...
Sandbox tools are basically a Ruby script that let you manipulate a triangulated mesh. Re-forming that shape later on in response to engineering speicifics is beyond sandbox, I think? With MaxonForm, the swoopy form is deformed from control points/lines..which can correspond to your structural supports (e.g., steel framework) - and so the swoopy shape redefines itself as you reposition those elements.
(Naturally, in either SketchUp or MaxonFom...as with most object-making...you want to keep the original elements in that program for subsequent editing. Too easy in MaxonForm to forget to save in c4d format before sending the result back to ArchiCAD...)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-02-09 12:06 PM
Karl wrote:You can reopen the GDL object created by MaxonForm again inside MaxonForm and the parametric objects are restored.Joeri wrote:For furnishings / entourage, this can be a useful method. But, for something that is to be actually built - the shell of a building for example - I don't think that the SU Sandbox tools are sufficient. Happy to be proven wrong though!
Archicad28/Revit2024/Rhino8/Solibri/Zoom
Archicad-user since 1998
my Archicad Book
