How to make Roof line on the plan correctly
When I draw the roof on the roof plan, the roof line is shown right at his story, but if I had the lower level awning then I go to the top roof plan, the awning right under the roof still shown the solid line ( should be hidden or dashed). Is there anyone have the same issue?
Eric
4 REPLIES 4
not exactly sure about the question but you can make the roof lines display in any way you like.
I have one upper roof, and lower garage roof see attached. the arrow pointed at the garage roof should be hidden or dashed.
eric
Try checking <cover fills> in floor plan display settings for your roofs. In this way, you will be able to bring to front the upper roof, while the hidden lines from your lower roof will stay invisible.
Hope this helps.
Cheers.
Adrian Tudoreanu
thanks a lot.
eric
