How to make an read only on Archicad
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2010-03-19 04:58 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-03-19 11:28 PM
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-03-22 12:22 PM
In Solo ArchiCAD you cannot really do this since even the Demo version is fully functional for 30 days.
Another solution is to publish the project as DWF files with the Project Reviewer environment included. Then they can view the whole thing, even make redlines to it, but not modify the original. You can later import the redlines they made. They will appear as Mark-Up entries in your project.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-03-22 03:55 PM
Mac OSX 10.11.1
AC5-18
Onuma System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-03-23 02:57 AM
Red Canoe Architecture, P. A.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-03-24 07:03 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-03-24 10:43 PM
If you just want them to be able to look at/print the plans, elevs etc then PDF or DWF outputs should do the trick.
If you want them to be able to "move around" the project, e.g. fly around it in the 3d window, select objects to see what tools have been used etc then I'm assuming you want them to be able to open the ArchiCAD file which would suggest the following:
1. Lock the file in your system e.g. Mac OS has a "locked" button in the File Info so it cannot be saved over etc unless unlocked - the effectiveness depends on how IT-savvy the other users are. This means that you have to remember to unlock the file to begin working, then lock it again once you have finished.
2. Lock all of the information in the ArchiCAD file by either locking the layers or locking all of the objects (Edit->Locking menu) or a combination of the two – the effectiveness depends on how ArchiCAD-savvy the other users are. Similar to 1 above you have to unlock the info to start working and lock it again afterwards.
3. Erika's suggestion of a Teamwork Project with view-only access for others is probably the most secure and easiest for you to be able to work with the file without having to unlock information.
4. Keep your "base" file hidden away in a secret location surrounded by (virtual) guard creatures of imposing size and ferocity, and link it as a module into an otherwise empty file that others can use to view it. This way the view file will always see your updated base file but cannot be changed (unless they break the hotlink, in which case I recommend changing jobs 'cos it's just too much effort).
That's about it from me - time for morning tea! 😄
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-03-25 01:11 PM
Or you might create a Work Environment that does not have any editing commands.
David
www.davidmaudlin.com
Digital Architecture
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-03-25 04:12 PM
Mac OSX 10.11.1
AC5-18
Onuma System
