How to make the structure?
Hello to everybody!
I'm new on the forum and it's my first time to post a thread. So I would be grateful if you can give me an advice or tip how to realize my project in Archicad. I want to make my project (shown on the scale model) using a metal structure (shown on the 2 images bellow the scale model), but I don't have idea how. Can someone give me advice how to start?
Thank you all!
17 REPLIES 17
Eduardo Rolon
After drawing the section for the Beam you would draw a Beam connecting to of the meshes points.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Eduardo Rolon
Apply the Complex Profile to the Beam
AC27 US/INT -> AC08
another Moderator
Eduardo Rolon
Then edit the elevation of the Beam to the Mesh node
AC27 US/INT -> AC08
another Moderator
Eduardo Rolon
Repeat as necessary
AC27 US/INT -> AC08
another Moderator
Eduardo Rolon
This should give a Basic model of what you need. The next items are designing the joints and adding more detail to the Beams by either convert to Morphs (right click and select convert to Morph) or redoing them with the Morph tool.
I might have skipped some details but I think you get the idea.
AC27 US/INT -> AC08
another Moderator
Thank you so very much! Without your instructions I wouldn't know even how to start. Well here is how my work is progressing so far.
And when I will come to the point when I have to put closure on this structure, like cover (curtain walls, roof structure) will it be possible to do so or not?
Thank you again for the help! I know that Archicad has so many opportunities and there is still so much for me to learn and to explore.
Eduardo Rolon
It all depends on how you design the cover.
The easiest is to have a Mesh with no thickness on top which is the easiest which is a copy of the same base mesh that you used to align the structure moved +6" in Z
If you need to have thickness for it you could convert the new mesh to a Morph and use the tools to offset the planes and then you can move the cover down.
AC27 US/INT -> AC08
another Moderator
Eduardo Rolon
Converting the Mesh to a Morph and editing it.
1. Select the Plane
2. Offset a copy of the plane to the inside
3. Delete the unneeded part.
AC27 US/INT -> AC08
another Moderator
