Thank you very much! I'll give both of those options a try.
ETA: In trying the first option, I installed the Accessories "goodie", but when I try to use it, under Libraries there is an empty folder titled "Missing Wall Accessory Objects". The goodie download page says that the library should be installed automatically. Any suggestions? Thanks.
E-again-TA: The library is in my Graphisoft directory, but I can't select it in the Library Manager. My theory is that it is because I am not running the most updated version of 17 (I can't update yet because the whole office has to be in sync). Does that sound like the likely reason?
On to try to figure out complex profiles
