How to reset settings in ArchiCad?
Im working on a project, and my cat actually managed to take a nap on the laptop keyboard.. It seems some settings have changed. I cant drag walls, and cant mark objects.
So I was wondering, is there someway I can reset all settings in archicad?
Ive tried to goto Options > Work environment > Work environment and double clicked the "norwegian version set".. It has always worked in the past whenever I've had a problem with something, but didnt work this time.
My deadline for this project is Monday 15th, so I dont have much time left:/
/anja
1 REPLY 1
TMA_80
Sorry...this is an unknown bug
more seriously, to reset ArchiCAD. press Alt+file/new & reset all.
you could then merge your file.
(sometimes, you don't even need to merge file; just reopen archicad ( in the openning file menu chose use latest projet settings _however it is more related to template afaik.) or you could chose the setup work environment and chose default profile.
AC12_27 |Win11_64bit|
