There is a library part called "Fill Types".
Place it and it will show all your fills in order of Fill Index numbers.
Or you can create a Schedule.
First explode the above library part. It will convert it to Fills so you will have a fill placed with each available Fill Type.
In the Scheme Setup Dialog, set "Fill" for element type to list.
For Fields to List, choose "Fill" and "Fill Type".
The Schedule will list all Fill Types alphabetically.
