How to use Wall End tool in Complex Profile (wall)
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2020-07-10
11:47 AM
‎2023-05-09
03:51 PM
Rubia Torres
‎2020-07-10
11:47 AM
I have made a complex profile (wall), but having a problem while I am trying to apply the 'wall end tool'. (See Fig-1)
It's not working. I am worried this tool doesn't work in Complex profile.
Can you guys help me with this issue?
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-07-10 12:54 PM
‎2020-07-10
12:54 PM
Hello avishiplu,
I know it possible to do it with wall end tool but I use to create my own custom column complex.
Perhaps you should try to disconnect these two walls because wall end tool is made for single wall.
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-07-10 03:34 PM
‎2020-07-10
03:34 PM
The most reliable way to generate a Wall End to a CP wall is to take the profile of your CP and create another CP wall that works as a wall end profile.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-07-10 04:00 PM
‎2020-07-10
04:00 PM
Christophe wrote:Hello Christophe
Hello avishiplu,
I know it possible to do it with wall end tool but I use to create my own custom column complex.![]()
Perhaps you should try to disconnect these two walls because the wall end tool is made for a single wall.
My Complex wall is made of 3 layers. I didn't get your idea on the column. I just need my complex wall will end smoothly. Right now the layer are exposed.
Can you please be more elaborative. Why do I need to disconnect walls, which is a part of the complex profile?
Sincerely
Avi
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-07-10 04:03 PM
‎2020-07-10
04:03 PM
DGSketcher wrote:Dear DGSketcher
Thanks for ur suggestion. Can you please be more elaborative.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-07-10 05:14 PM
‎2020-07-10
05:14 PM
@avishiplu. The wall end tool works quite happily with Composite Profiles as they are typically rectangular and predictable. With Complex Profiles Archicad gives the flexibility to create shapes that in section can be random and broken into parts, so asking the wall end tool to determine what the user wants as an end cap is a bit of a tall order. I suggest you copy the contents of your wall complex profile to a new complex profile and then edit those shapes to create an end cap profile with the materials you want. In your model you can then use this new profile as an end cap by extending your wall with the new profile.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-07-13 03:41 AM
‎2020-07-13
03:41 AM
If your wall is symmetrical or flat on one side, you could try using a segmented column?
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
