How to view, edit length when grouped?
So when lines, shapes, walls etc are grouped or using fills you cannot click a length and view and editing the length, you need to ungroup if its a fills theres no way at all. is there a way to view and edit a length whilst it is still grouped?
You can suspend groups.
This way you preserve the group but still can edit elements.
Lingwisyer
Guru
You can use the Marquee Tool to make a selection around the elements while groups are suspended that you wish to stretch then use the move command (ctrl + d) to move all unlocked nodes within the selection area.
Ling
