How too make connected walls and roofs with radius
Hello everyone
I'm new in Archicad and wanted to ask how can i make walls and slabs such like this?
any help will be appreciated.
6 Replies 6
Check out this thread for example:
http://archicad-talk.graphisoft.com/viewtopic.php?t=39950
Thank you very much laszlonagy.
is there another way except complex profiles or this is the only way to do that?
I has made a very similar building the last week for a contest... (sorry no pics) I made a shell for the slab and the curve walls like a S. First in the plan and then rotate. Then with seo I sustract a standar wall with the shell...
Check this thread too! There are several ways to model this but complex profile is the easiest for now.
http://archicad-talk.graphisoft.com/viewtopic.php?t=32227&highlight=
that sounds great Jose Gemez,a tricky,smart way to model it, i saw here the rotator.gsm object...did you rotate them with this object? thanks for tip
thank you kliment,this thread helped me so much,nicely done project without using complex profile by the way.now i'm getting used to it
