How was this acheived ?
i just read on the graphisoft website about this .
http://www.graphisoft.com/community/press_zone/jury-biotechlab.html
looks fantastic but im very curious about how he formed the base and ergonomic columns tieing into the main biulding structure ?
i would be very interested to see what would be the strategy to pulll this form off ?
thanks.
Ian
30 REPLIES 30
Eduardo Rolon
changing floor plane height or going up a story displays correctly.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
again
AC29 US/INT -> AC08
another Moderator
looks very interesting but can you explain a little more about how you created this form without SOE ?
Thanks.
Ian
Eduardo Rolon
The form is created using SEOs. The only thing that I changed was the tool I started with.
Instead of starting with a Slab in which I created holes which will not display correctly in plan, I started with a Extruded Shell which will display correctly on plan.
The holes can be created with either empty skylights or by SEOs.
The rest of the procedure is the same as before.
AC29 US/INT -> AC08
another Moderator
this looks great.
can you please explain in a few steps what you did to create this ?
sorry for all the newby questions.
best wishs and thanks.
Ian
how can i use the Extruded Shell tool to create a box going up ?
Ian
Eduardo Rolon
Draw a box using the custom polygon method on plan, see image, when you close the polygon AC will extrude it vertically.
The width of the shell should be half the width.
AC29 US/INT -> AC08
another Moderator
brilliant helpful tip !!
so
1. create on plan, design of extrusion unit.
2. pick shell tool and select plan for extrusion.
3. extrude.
4. create elevation view.
5. in elevation view create spline line for extrusion rotate profile.
6. copy spline.
7. go back to plan and paste in spline line.
8. using spline line, use shell tool.
9. rotate soldobject 90 degrees,
10. use solid object editing SOE to subtract new shell element from original extrusions.
11. BINGO !
Ian
ps. this version i just tested, works for sections, elevations and plans.
im proud of my first working SOE curved surface model with working plan and elevations !
Ian
and the working plan.
