2009-10-20 04:43 PM
2009-10-20 08:46 PM
2009-10-20 09:28 PM
2009-10-20 09:43 PM
Master wrote:Great ! What thickness would you use, it's only about 2mm thick so should I just use that ? Did you use the default roof setting, or should I manipulate them from my model, likewise the height of the ' walls' i.e if its 25mm high I would raise the walls 25mm high then put the roof on and trim ?
It is quite a challenge, but it can be done.
1 draw the contour with walls
2 place a roof
3 trim to roof
4 make an object (axonmetric top view, save 3D model as)
5 place the object
6 redo for second element, but add a rotation factor in the top of the 3D script (ROTY 10, or ROTX 10 or ROTY 10, which depends on your object)
7 add this line to the 2D script PROJECT2 3,270,1 for correct 2D view
8 you might want to adjust the position in an elevation
9 and so on . . .
good luck!
2009-10-20 10:01 PM
2009-10-20 10:29 PM
2009-10-20 10:56 PM
2009-10-20 11:25 PM
2009-10-21 01:54 AM
2009-10-21 01:57 AM
