2020-03-24
09:40 AM
2023-05-26
12:25 PM
Rubia Torres
2020-03-24 11:43 AM
2020-03-24 03:27 PM
2020-03-30 04:40 AM
2020-03-30 07:59 AM
LaszloNagy wrote:
The attached ZIP file contains the PLA file in which I modeled this scenario using a Segmented Column and a Segmented Beam.
The image shows how the geometry was segmented and the widths and height of segments calculated.
In case of the Column you have to slice it into Segments wherever there is any change in the thickness of the Flanges or the Width. Segments are either Rectangular, or I-Profile with Parametric Modifiers, in which the thickness of two Flanges can be modified independently. All Segments are Tapered.
The Beam is similarly segmented. In case of the Beam, distances must be measured parallel and perpendicular to the inclined upper line of the Beam.
