We are experiencing a temporary disruption to our cloud licensing service. Our team is working to resolve the issue as quickly as possible. We appreciate your patience and support.
I broke the GDL ... seriously no joke
Nader Belal
Mentor
Hi everyone,
This is not a noob question.
Well I have 2 array parameters that are to be used for a Values{2} function, but Archicad refused to execute it because it have identified the string array parameter as numeric array parameter.
Yes I have checked if it was written correctly, and Yes I have already used VARTYPE function to make sure that that the String array is in fact a string Array.
I need to know who did I break the GDL ? and how to fix it ?
Nader Belal
Mentor
To all of you thank you.
I just solved it be eliminated an iteration that somehow, its content or it's location in the Parameter script wasn't of Archicad liking.
7 REPLIES 7
DGSketcher
Legend
Couple of suggestions...
Try running a loop to clear / initialise / overwrite all the array values with a string.
Create a new array with a similar name and delete the old one.
I will try number 2, number one is already implemented
No use, ...
I even tried to use the temporary variable array, and the message still is persistant
Nader Belal
Mentor
Last Update:
I created a new empty GSM file with the same parameters, then copy pasted the code from the original file to the new one.
Didn't work, same error message
With out the object or code posted it's probably going be impossible for us to help.
Could you attach an example?
Industrial Architect and Structural Design Engineer, developer of free addon for sync GDL param and properties
Nader Belal
Mentor
