I can't trace the pipeline.
retdot
I made a template that is convenient for me to work with. The template represents a project I have already completed. In this template, I also laid out cold and hot water routes, sewerage and ventilation. Everything worked fine, almost. Now, I am making my new project in this file, but when I start laying a route on the floor plan, the panel does not appear in which the direction (vertical or horizontal) is indicated. I just can't find this panel! I changed the profile to MEP, but it didn't helpСнимок экрана 2024-06-30 181236.pngСнимок экрана 2024-06-30 183127.pngСнимок экрана 2024-06-30 183521.png
Operating system used: Windows 10
4 REPLIES 4
Nurbs
Hi retdot,
In Archicad 27 you won't find the routing palette anymore because of a new MEP Tool:
https://help.graphisoft.com/AC/27/INT/index.htm#t=_AC27_Help%2F005_NewFeatures%2F005_NewFeatures-16....
If you want to have the routing palette you'll have to stay with AC 26.
AC16 - AC29, Rhino 5-8. Alienware WIN 11
Yes I understand. I just don’t understand why it’s impossible to make a vertical pipeline on the plan now? In each new version of Archikad, a new bunch of tabs and submenus appear. Some things in the interface are duplicated 3 times! The program began to resemble a trash can where both good and bad are thrown away. Do you really think that users expect a garbage interface from you?!!
Hi @retdot
Sure, there're major changes for MEP modeling from AC26 to 27 & that's accompanied with some enhancements.
For creating the vertical branch of the pipe or duct route you can draw the whole wrote or a segment of it in floor plan then via 3d view you can offset the segment vertically, see attached Screenshots.
Screenshot 2024-07-01 052757.pngScreenshot 2024-07-01 052859.pngScreenshot 2024-07-01 052914.png
AC 28 INT 5200/WIN 11
Why doesn't the MEP library load by default when you switch the profile to MEP engineer? Wouldn't that be logical? I spent all day yesterday to understand that it turns out that I simply did not have the MEP library loaded, so all the drawn elements look like dots on the plan. The Grafisoft team cannot make a floating message that would say that “the library is not loaded, your object will not be displayed on the floor plan and in 3D.”
Setup info provided by author
