2022-11-23
04:46 PM
- last edited on
2023-05-09
02:01 PM
by
Rubia Torres
1) I'm trying to make a normal door but when I click on the wall come out of the arches with darts, but the door is not created, what should I do? 2) Why the wall even if above is identified as a wall in plastered blocks, the graphics of the wall is white and not checkered?
Thank you
Solved! Go to Solution.
2022-11-24 10:38 AM
Hello,
Your wall is diplayed as uncut, that's why the door is'nt drawned.
Two reasons : your wall is set to allways show uncut in it's Plan/Section settings, or the top of the wall is under the section plan of the plan vue.
2022-11-24 02:23 AM
You need to click twice with doors. One to set position, two to set opening direction.
Ling.
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
2022-11-24 04:37 AM
There is a problem in the wall: 1) why does it have a different plan graphics from the other wall even if they are always two walls as plastered blocks? 2) because in section you see the door that I inserted but the view you see the wall at the end of the room, you should not see the room behind the wall 3) it seems that the wall is not there and yet in plan is selectable? Thank you
2022-11-24 10:38 AM
Hello,
