2017-11-25 09:21 PM - last edited on 2023-05-26 02:14 PM by Rubia Torres
2017-11-27 01:39 AM
2017-12-06 12:15 AM
Barry wrote:
Welcome to the forum.
But first please read the section descriptions to find the best place to post.
I have moved this post.
Because the slats are horizontal you could easily do this with a 'Complex Profile' wall.
The opening is a little different depending on what you want to do.
You can add an empty opening in the complex profile wall and then create a second complex profile wall for the open panels.
However this will be fixed at that angle and will not be adjustable unless you further edit that profile.
If you want a parametric (moveable) window then you will need to learn a bit of GDL as I have not seen any default windows or doors like that.
