Display malfunction of Graphisoft ID dashboard
Learn more
3D detailing (from model)
just wondering if it is possible to derive a 3d detail from a model where you could adjust the cutting planes of multiple elements at differing depths (even if it were just 3 to start with) different cutting plane depths in the same orientation without having to manually trim or rebuild the detail entirely seperately from the standard house model?
Image attached to show what im talking about
4 Replies 4
Erwin Edel
You could try peeling away layers with hidden elements with higher priority building materials. Still a tedious process.
In the end it is just another still image. Just share your model, stuff the info in there
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
MrC
i can generate a similar image by adjusting the elements for length & height etc from a saved view. Adjustable multiple cutting planes would be a good wish.
ILIFFE ARCHITECTURAL
BRITISH COLUMBIA
macbook pro 2.7 GHz Intel Core i7 8 GB 1600 MHz DDR3 NVIDIA GeForce GT 650M 1024 MB
AC 21 USA (latest build)
Hi MrC looks good
could you explain in a little more detail how you achieved that?
is that from a 3d document file and how do you adjust the lengths, were they adjusted before or after?
Steve Jepson
SEO
