I need help by bahama windows
Hi guys, I'm studying 3rd semester architecture, and kinda new to Archicad. I'd like to create a cover for the facade somewhat like this:
All I need is just the wood shuttering outside, and it should be folded horizontally like that. I've been googling for 5 hours how I can create its 3D model on Archicad and found absolutely nothing. Could anyone please show me how can I create/ found such system? I'm using Archicad 20 btw.
Thank you in advance
Welcome to the forum.
But first please read the section descriptions to find the best place to post.
I have moved this post.
Because the slats are horizontal you could easily do this with a 'Complex Profile' wall.
The opening is a little different depending on what you want to do.
You can add an empty opening in the complex profile wall and then create a second complex profile wall for the open panels.
However this will be fixed at that angle and will not be adjustable unless you further edit that profile.
If you want a parametric (moveable) window then you will need to learn a bit of GDL as I have not seen any default windows or doors like that.
Thank you for your suggestion, and I'm sorry for posting in the wrong place! I will do research on GDL then
