I need help importing a file from Autocad...HELP
i AM TRYING TO IMPORT A FILE OF AN EXISTING HOME INTO AUTOCAD FOR A REMODEL PROJECT. I am "placng external content" in the form of a DWG file, which is plunking down the Autocad file like one big image. Is it possible to keep the elements and layers of the autocad file separated so I can manipulate the lines and elemnts in Archicad, or do I have to use it as a trace refernce only???? PLease help I am a novice... Thanks!!!
Eduardo Rolon
Edit Menu,
Reshape
Explode into current view
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
