2010-11-11 01:43 PM - last edited on 2023-05-26 12:20 PM by Rubia Torres
2010-11-11 03:30 PM
2010-11-11 03:51 PM
Matthew wrote:Another trick is to select just a few elements from plan view, open a partial 3D window with de F5 key (F4 on the mac), and THEN go to de cutting planes settings.
The trick with this one, since the view panes are so small, is to type in the Z height for the cutting plane(s) and use shift to constrain it to the horizontal.
2010-11-12 10:00 AM
2010-11-13 03:43 PM
2010-11-13 07:14 PM
2010-11-13 10:27 PM
Paul wrote:As a rule I prefer to stack walls than to extend them through multiple stories. I typically use the multi-story wall only when the fenestration does not align with the floor plates or the enclosed spaces are also multi-story (as at atria and such). Of course much of my work these days is construction coordination where we have to split the export models story by story for the MEP guys and I like to keep complications to a minimum.
Anne, as you bring up the issue...I was wondering if someone has general advice about whether it's better to make walls which are X (five or six typically in my case) high and then set stories at the correct elevations, or whether it's better to stack slab and wall assemblies one on top of the other.
We are working in a city (NY) where 25' wide row houses with perimeter masonry walls up to six stories high is a very typical form of construction, and we regularly do alterations and extensions to those types of structures. I don't have enough experience with ArchiCAD to know which, in a general sense, is a better approach.
Thanks for any advice,
Paul
2010-11-13 11:38 PM
Matthew wrote:Thanks for the recommendation, I have been using the tall walls approach, but I will try the stacking approach. I certainly appreciate the advice of an experienced user.
2010-11-17 05:17 PM
2010-11-18 01:27 AM
Krippahl wrote:Thanks for your thoughts (ol' geezer here as well, though not with AC). I'm beginning to be convinced that one wall per floor is the best way to model things in ArchiCAD.
We ol´ geezers tend to make one wall per floor, because for many years that was the only way in ArchiCAD to model them.
That said, I also use the one wall per floor because that is the way most walls are really build, and building them virtually as they build them on site has many advantages downline.
If you have a long term goal to make your models available to the construction company (and what is BIM about but sharing models), then your workflow should emulate as closely as possible the construction one.
