I would like to change only the standard story in the current state.
LeeJaeYoung
1. BEAM
AC27 on window 11
Xandros
Hi
you can right-click the element and then use the function Relink Home Story
Further information: https://help.graphisoft.com/AC/26/INT/_AC26_Help/040_ElementsVB/040_ElementsVB-4.htm#XREF_90811_Reli...
ArchiCAD 27 GER / Win10
Intel i9-9900K / 64GB RAM / nVidia GeForce RTX 2080 Ti
Xandros
Hi
thank you so much ^^
AC27 on window 11
