ID Manager for Column numbering
ratnabhirud
I have some columns having same / different ID number just because of my wrong placement .
Now I want them to number in 'Right to left and up to down order'.
How I should use ID Manager for this?
Thanks & Regards,
Ratna
AMD Ryzen 5 3600 6-Core Processor 3.59 GHz
Ram - 16.0 GB
System - Windows 10 Ultimate, 64 bit
NVEDIA GForce 8400GS
Archicad 9..., 24
4 REPLIES 4
Steve Jepson
they can be renumbered in the order that you select them.
Steve Jepson
these are selected from right to left starting at the top.
The renumbering is per the order in which the columns were selected holding down the shift key of course.
ratnabhirud
Thanks for your quick reply.
I have done as per your instruction, but not getting the result.
I have these columns as in attached image.
What should I do the settings in 'Sort Element' tab in Element ID Manager dialog box?
Thanks & Regards,
Ratna
Ram - 16.0 GB
Archicad 9..., 24
ratnabhirud
Hello Steve,
Finally got the solution of ID Manager for the column!
Regards,
Ratna
Ram - 16.0 GB
Archicad 9..., 24
