ID field including the hotlink name
I thought I knew how to keep the hotlink name from being included in the element ID of anything from a hotlink. For example, if I have a door ID "01" in a hotlinked file named "common walls", the ID coming in for that door is now "common walls01". Can this be made not to occur and be "01"?
OK! The Text" Common Walls" was coming from the MASTER ID of the hotlink! So, to keep text like this from being concatenated to the ID number, the MASTER ID must be empty.
