IFC Add-on Commands
Hello
Has anyone got any documentation about commands that are exposed for the IFC Add-on ?
I want to save as IFC from my Add-on , is there a better way to do this? Am I barking up the wrong tree?Or just "barking"?
Kind of frustrated with lack of information , there is an example in the API documentation of how to ask DWX Input Output (or what ever its called) add-on to 'save as' . But I can n't see any documentation of the commands exposed for that Add-on either.
So given that IFC is ment to be used for interoperability - how do I ask ArchiCAD to save as IFC from my Add-0n -
Any hints would just be fantatic
1 REPLY 1
GKiss
Graphisoft Alumni
Graphisoft Alumni
Hello Todd,
You can download the newest IFC add-on from the next URL:
http://www.graphisoft.com/support/ifc/downloads/public/
If you install it you can find IFC user's guide; "IFC_Guide_2xEd2_v3p5.pdf" in the "<ArchiCAD folder>/ArchiCAD Documentation" folder
Anyway it is recommended to download the last IFC add-on from the above URL because the IFC add-on in ArchiCAD package is 1/2 year old and we corrected some bugs in the newer version.
Regards,
Gyula
