Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Archicad design tools: Workflows, element connections, modeling tips
IN AC9 we had Intersect Walls, IN AC10?
I got tired of looking for the menu item "Intersect Walls" in AC10 (we had it in AC9), where is it?
Thanks,
Joseph
5 REPLIES 5
__archiben
there is no 'intersect walls' command: it's just 'Intersect'. should be somewhere in your edit menu . . . probably under the 'Reshape' sub-menu . . . ?
~/archiben
b e n _ f r o s t
Now you can intersect everything with everything (almost) !
Link
Walls, Beams, Lines, Arcs. That's it right?
Link.
"Almost" is the key word, Link!
Interracial marriages still not allowed (lines and walls). There are some religious restrictions too (lines and splines).
Just like life! šŸ˜‰
Djordje
CTRL Click still works ...
... universally ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
