G Ahern
Idiot Mistake - Help (exited without saving)
Oops.
Worked for several hours (with auto-save on)
When it came time to exit, I accidently hit "exit without saving".....
OUCH!
Is there a way to retreve work.. or did I just learn a valuable lesson?
I did check the backup file and it did not have any of the work...
(yes.. that loud scream you just heard was me...sorry)
thanks in advance
Gary J Ahern, AIA
AC 19 - Windows 10(64 bit)
Dell Precision M6800
FAILURE IS NOT AN OPTION! It comes bundled with the software.
Focal Point Design
1150 El Camino Real, #200
Menlo Park, CA 94025
(650) 326-2800 phone
www.garyahern.com
2 Replies 2
I fear you learned a lesson the hard way. Wise to press ctrl-s / cmd-S reasonably often to make sure your BPN file is not as far out of date was yours apparently was.
This article:
http://www.archicadwiki.com/AutoSave
gives the default autosave location for Mac... but I just checked there, and I have no autosave files, so apparently the files are erased after a normal exit? Maybe it is different on Windows.
This thread may be helpful, but equally unsatisfying:
http://archicad-talk.graphisoft.com/viewtopic.php?t=7277&start=0&postdays=0&postorder=desc
I know the feeling, but as Karl said there is nothing u can do about it.
just have to bite the bullet and start again
