ā2007-08-21 04:06 PM
ā2007-08-21 06:56 PM
Jesikuh123 wrote:No, not the title block. But, you can transfer the master sheets themselves. Open Organizer and in the left panel, open the project that has the updated masters. In the right panel, display your current layouts/masters for the active projects. Just drag the updated masters across. [It's not actually quite so simple, since the masters with the same name will get a new name...and you'll have to make the new one the default, rename old/new, assign new to layouts, delete old... Hmmm. Sounds like a lot of work! Worth it if there are lots of masters. If not, copy/paste of the content - title block in your case - sounds much easier!]
Is there a way I can Import Master Title Blocks, instead of copying and pasting them?
And is there a way so that if I change the title sheets in my template they will universally change in all projects using that template.Well, if GS had made life consistent, we would be able to place hotlinked modules in a master layout. But, we cannot. Nor, can we place xrefs on a master.
And is that the advantage to using and Actual Template, as opposed to renaming a blank Project and using that as the template?
ā2007-08-21 07:02 PM
ā2007-08-21 07:09 PM
Karl wrote:In both this (placed drawing) and your (placed object) approach, hotspots would have to be manually added to allow snapping to the placed element(s)...
Indirectly, you can create a module for the title block. Hotlink that module into an independent Worksheet (or Detail). Place a drawing based on that Worksheet on the Master.
ā2007-08-21 07:13 PM
Karl wrote:How would that be any different than just drawing it in a Detail/Worksheet without the module? (assuming it's all drawn in one central PLN)
Ha. I knew someone would post before I could re-edit my post!
Tom, I think this would work? Haven't tried it:
ā2007-08-21 07:22 PM
TomWaltz wrote:...and then just placing an external drawing, based on that Worksheet, on the master in each project? I guess not much difference - just network traffic for the larger PLN file from the server during drawing update, vs the single small module transmission at hotlink update time. Unless the master attempts to update its external drawings each time it is used in a layout...?
ā2007-08-21 08:06 PM
Karl wrote:I don't think a PLN with just the title blocks would be that big, especially considering it would only need to update when the title block changes.TomWaltz wrote:...and then just placing an external drawing, based on that Worksheet, on the master in each project? I guess not much difference - just network traffic for the larger PLN file from the server during drawing update, vs the single small module transmission at hotlink update time. Unless the master attempts to update its external drawings each time it is used in a layout...?
I don't usually post without testing, so I see I'm digging myself a hole...š
ā2007-08-21 08:48 PM
ā2007-08-21 08:52 PM
ā2007-11-30 07:34 PM
