Importing multiple sheets from AutoCAD files
I had an old project from my autocad days rear its ugly head recently and I need to make some changes. the file I need had multiple paperspace layouts as well as the model space. I can import the model space just fine into either AC or PM, but I am having trouble getting to the paperspace views, which is where I have all my keynotes, legends....
the one file has about 10 paperspace sheets, so I really do not want to recreate those, any tips would be appreciated. Of course, if all else fails, i suppose I still have my pencils and eraser.
1 REPLY 1
Eduardo Rolon
In the Merge option in AC when you select the translator, if you select settings, under Open Options, change the drop down of "Import Drawing Data from" from Model Space to Paper Space.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
