2005-03-10 10:36 PM - last edited on 2023-05-23 05:22 PM by Rubia Torres
2005-03-11 08:00 PM
2005-03-11 08:19 PM
Joseph wrote:
How does everyone creates an Index Sheet showing what a symbol like elevation means. To say this is ELEVATION of a building?
2005-03-11 09:37 PM
woodster wrote:Yes, yes that is what I am looking for,
If I understand you, just create an empty elevation with sample text instead of auto text. Do you mean like this...
woodster
2005-03-11 09:59 PM
Joseph wrote:
How do you make an empty elevation I thought we can only have independent details?
Joseph wrote:
Also what do you mean by sample text vs. auto text?
How can put this index on a independent details, or can I?
2005-03-11 10:15 PM
woodster wrote:Great,
Just draw an Elevation line; it is not necessary that it to point to anything to appear (and don't include it in your View Set).
woodster
2005-03-11 10:27 PM
Joseph wrote:
1. As I understand this should all be done on a Story (vs. an independent detail) perhaps called "Index" then create a View Set and import it to PM, am I correct?
Joseph wrote:
2. And how do you created the Window Marker on this plan without having a wall to insert the Window so one can show the Marker of it?
2005-03-11 10:49 PM
woodster wrote:Wow woodster, you really do not like to think inside the box.
Now you want to know all my secrets???
I put an Empty Door into a wall that was not as long as the door was wide and turned the contours off (see picture)
woodster
2005-03-13 07:01 PM
