‎2004-08-11 07:01 PM
‎2004-08-11 07:57 PM
‎2004-08-11 11:37 PM
Erika wrote:Thanks a lot, this is what I was looking for. But where do I actually type in my text, I could not do it in I.S. itself?
Under Calculate
I/S
Settings: Select your 'wall list' schedule
Fields Tab: click on 'Additional Parameters'
1. Set it on 'All types by subtype'
Model element Type: check 'Wall'
2. Under 'Show Parameter Types' have only 'Abc' (text) active
3. check off parameter 'User Defined 1'
‎2004-08-12 12:33 AM
‎2004-08-12 02:27 AM
Erika wrote:In reality I would like to get all composite wall skins extracted to a Interactive Schedule, Yet as far as I know it is not possible. The other work around would be (not so efficient) to type in the actual make-up of the wall (2x4 @ 16" O.C., 1/2" Ply Wood, 5/8" Gyp-Brd each Side) in user define field,
Joseph,
What are you trying to do?
What kind of comment(s) are you wanting to enter?
.........so someone else please chime in.
