ā2003-11-12
11:18 PM
ā2023-05-26
03:30 PM
Rubia Torres
ā2003-11-13 12:36 AM
ā2003-11-13 12:57 AM
ā2003-11-13 08:26 AM
ā2003-11-13 12:58 PM
johncassel wrote:On top of all the good advice you already got:
I am trying to create interior elevations of my current project--a 2 story residence.
ā2003-11-13 09:54 PM
ā2003-11-14 09:15 AM
johncassel wrote:That is because they are objects.
I am going to play with creating and editing the interior elevations. I noticed that the normal tools do not seem to be avalible in the generated interior elevation.
The manual says that the interior elevations can be cut and pasted to a Plan or Section/Elevation window. Is that it? Does this tool only generate a snapshot of the current elements?Yes, and updates them as needed - which does exactly nothing for the stuff that you copied and pasted. Very un-Virtual Building like. A good tool with completely wrong implementation.
If that is the case then I will probably go ahead and generate limited Elevations of the interiors. A least those can be dimensioned, edited and updated.... and, most importantly, they are alive all the time - Virtual Building, remember?
Thank you for getting me started.Pleasure
