Internal cut error while generating a section
Why does ArchiCAD lock up while generating a section. It asks whether to stop of continue. The report indicates a Internal cut error.
What's up with that?!
4 REPLIES 4
TomWaltz
Is that all the error box says? Or is there more to the error?
Tom Waltz
When it asks to stop or continue, I select stop. When I selected continue, the program crashes.
The full error message reads:
"Beginning generation of Section/Elevation:
Start time : Fri, Jun 9, 2006 11:22:48 AM
Document name : VH_2-B1.pln
Processed : 96 walls 222 objects 167 columns 103 ncBeams
57 slabs 0 meshes 48 pitch roofs
End time : Fri, Jun 9, 2006 11:22:58 AM
Elapsed time : 10 seconds
Internal cut error #24.
Creating section
*** User Break ***
End time : Fri, Jun 9, 2006 11:23:01 AM
Elapsed time : 2 seconds
Projection : Side view
*** User Break ***
Elapsed time : 0 seconds
Finished generation of Section/Elevation.
Elapsed time : 13 seconds"
Date/Time: 2006-06-09 15:31:57.461 -0600
OS Version: 10.4.6 (Build 8I127)
Report Version: 4
Command: ArchiCAD
Path: /Applications/Graphisoft/ArchiCAD 9/ArchiCAD
Parent: WindowServer [63]
Version: 9.0.0 v1 USA (9.0.0 v1 USA (8306 / 2045), Copyright Ā© Graphisoft R&D, 1984-2004)
PID: 270
Thread: 0
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_INVALID_ADDRESS (0x0001) at 0x70220954
Thread 0 Crashed:
0 GSModelerLib 0x036c2f28 0x35b7000 + 1097512
1 GSModelerLib 0x036c7c38 0x35b7000 + 1117240
2 GSModelerLib 0x036c6aa0 0x35b7000 + 1112736
3 GSModelerLib 0x0375cd14 0x35b7000 + 1727764
4 GSModelerLib 0x037581c8 0x35b7000 + 1708488
5 GSModelerLib 0x03758540 0x35b7000 + 1709376
6 ArchiCAD 0x02d658c0 0x2008000 + 14014656
7 ArchiCAD 0x02d6a0b0 0x2008000 + 14033072
8 ArchiCAD 0x02d6b43c 0x2008000 + 14038076
9 ArchiCAD 0x02d6c5bc 0x2008000 + 14042556
10 ArchiCAD 0x0241cdcc 0x2008000 + 4279756
11 ArchiCAD 0x02e3a660 0x2008000 + 14886496
12 ArchiCAD 0x02e3d3fc 0x2008000 + 14898172
13 ArchiCAD 0x02e767d0 0x2008000 + 15132624
14 ArchiCAD 0x02e11160 0x2008000 + 14717280
15 ArchiCAD 0x02e76274 0x2008000 + 15131252
16 ArchiCAD 0x02e10d2c 0x2008000 + 14716204
17 GSRootLib 0x004d0dec 0x444000 + 577004
18 ArchiCAD 0x030c8614 0x2008000 + 17565204
Thread 1:
0 libSystem.B.dylib 0x9000b0a8 mach_msg_trap + 8
1 libSystem.B.dylib 0x9000affc mach_msg + 60
2 ...ple.CoreServices.CarbonCore 0x90bad5ec TS_exception_listener_thread + 112
3 libSystem.B.dylib 0x9002ba68 _pthread_body + 96
Thread 2:
0 libSystem.B.dylib 0x90054fc8 semaphore_timedwait_signal_trap + 8
1 libSystem.B.dylib 0x90071648 pthread_cond_timedwait_relative_np + 556
2 ...ple.CoreServices.CarbonCore 0x90c06f4c MPWaitOnSemaphore + 184
3 ArchiCAD 0x02745a74 0x2008000 + 7592564
4 ...ple.CoreServices.CarbonCore 0x90c3a614 _MP_CFMTaskProc + 32
5 ...ple.CoreServices.CarbonCore 0x90bc9260 PrivateMPEntryPoint + 76
6 libSystem.B.dylib 0x9002ba68 _pthread_body + 96
Thread 3:
0 libSystem.B.dylib 0x90005f6c syscall + 12
1 com.apple.OpenTransport 0x9a3705a0 BSD_waitevent + 44
2 com.apple.OpenTransport 0x9a375360 CarbonSelectThreadFunc + 176
Thread 4:
0 libSystem.B.dylib 0x9002c128 semaphore_wait_signal_trap + 8
1 libSystem.B.dylib 0x90030bec pthread_cond_wait + 480
2 com.apple.OpenTransport 0x9a370e94 CarbonOperationThreadFunc + 80
Thread 5:
2 com.apple.CoreFoundation 0x907e3b78 __CFRunLoopRun + 832
3 com.apple.CoreFoundation 0x907e347c CFRunLoopRunSpecific + 268
4 com.apple.audio.CoreAudio 0x9148d83c HALRunLoop::OwnThread(void*) + 264
5 com.apple.audio.CoreAudio 0x9148d5dc CAPThread::Entry(CAPThread*) + 96
Thread 6:
0 libSystem.B.dylib 0x9002edcc kevent + 12
1 com.apple.DesktopServices 0x9288b2b0 TFSNotificationTask::FSNotificationTaskProc(void*) + 56
2 ...ple.CoreServices.CarbonCore 0x90bc9260 PrivateMPEntryPoint + 76
Thread 7:
2 ...ple.CoreServices.CarbonCore 0x90bc9450 MPWaitOnQueue + 224
3 com.apple.DesktopServices 0x9288b92c TNodeSyncTask::SyncTaskProc(void*) + 116
4 ...ple.CoreServices.CarbonCore 0x90bc9260 PrivateMPEntryPoint + 76
5 libSystem.B.dylib 0x9002ba68 _pthread_body + 96
Thread 0 crashed with PPC Thread State 64:
srr0: 0x00000000036c2f28 srr1: 0x100000000000d030 vrsave: 0x0000000000000000
cr: 0x28002242 xer: 0x0000000020000000 lr: 0x00000000036c2ed8 ctr: 0x00000000035ea930
r0: 0x000000005f0994d0 r1: 0x00000000bfffde70 r2: 0x000000000421d000 r3: 0x0000000070220950
r4: 0x0000000011187480 r5: 0x00000000fffffbaa r6: 0x00000000abe132a6 r7: 0x0000000000000004
r8: 0x00000000fffffffe r9: 0x0000000000001000 r10: 0x00000000bfffe218 r11: 0x0000000000000000
r12: 0x00000000042191c8 r13: 0x0000000000000000 r14: 0x000000000f7ed6c8 r15: 0x00000000bfffe218
r16: 0x0000000000000000 r17: 0x000000000000000c r18: 0x00000000abe1329a r19: 0x0000000000000000
r20: 0x0000000000000005 r21: 0x0000000000000000 r22: 0x0000000000000000 r23: 0x00000000fffffff9
r24: 0x0000000000001305 r25: 0x0000000000000000 r26: 0x0000000000000004 r27: 0x0000000000000005
r28: 0x0000000000001000 r29: 0x00000000bfffe7ac r30: 0x000000000f75f010 r31: 0x0000000000000002
Binary Images Description:
0x1000 - 0x2fff LaunchCFMApp /System/Library/Frameworks/Carbon.framework/Versions/A/Support/LaunchCFMApp
0xcb000 - 0xcbad4 ArchiCADDialogLib PEF binary: ArchiCADDialogLib
0xdc000 - 0xf0c5d InternetURLLib PEF binary: InternetURLLib
0xf1000 - 0xf694c VBAttrControlsLib PEF binary: VBAttrControlsLib
0xf7000 - 0xfe862 ProjectFileLib PEF binary: ProjectFileLib
0xff000 - 0xffad4 ArchiCADMenuLib PEF binary: ArchiCADMenuLib
0x27f000 - 0x2ce3c7 CarbonLibpwpc PEF binary: CarbonLibpwpc
0x2ce3d0 - 0x2e66bd Apple;Carbon;Multimedia PEF binary: Apple;Carbon;Multimedia
0x2e7c00 - 0x2e998b Apple;Carbon;Networking PEF binary: Apple;Carbon;Networking
0x2ea000 - 0x2fde3f LibPartFileLib PEF binary: LibPartFileLib
0x2fe000 - 0x2ff52f WkMAC.LIB PEF binary: WkMAC.LIB
0x311a90 - 0x311b21 CFMPriv_AGL PEF binary: CFMPriv_AGL
0x311ce0 - 0x311d92 CFMPriv_CoreFoundation PEF binary: CFMPriv_CoreFoundation
0x311fa0 - 0x312055 CFMPriv_DVComponentGlue PEF binary: CFMPriv_DVComponentGlue
0x312290 - 0x312333 CFMPriv_QuickTime PEF binary: CFMPriv_QuickTime
0x3123b0 - 0x312427 CFMPriv_System PEF binary: CFMPriv_System
0x3126d0 - 0x3127a0 CFMPriv_CarbonSound PEF binary: CFMPriv_CarbonSound
0x312820 - 0x3128f3 CFMPriv_CommonPanels PEF binary: CFMPriv_CommonPanels
0x3129d0 - 0x312a8b CFMPriv_Help PEF binary: CFMPriv_Help
0x312a90 - 0x312b5a CFMPriv_HIToolbox PEF binary: CFMPriv_HIToolbox
0x312be0 - 0x312cb6 CFMPriv_HTMLRendering PEF binary: CFMPriv_HTMLRendering
0x312d30 - 0x312e03 CFMPriv_ImageCapture PEF binary: CFMPriv_ImageCapture
0x312e90 - 0x312f75 CFMPriv_NavigationServices PEF binary: CFMPriv_NavigationServices
0x312ff0 - 0x3130c6 CFMPriv_OpenScripting?MacBLib PEF binary: CFMPriv_OpenScripting?MacBLib
0x3131a0 - 0x31325e CFMPriv_Print PEF binary: CFMPriv_Print
0x313280 - 0x31334d CFMPriv_SecurityHI PEF binary: CFMPriv_SecurityHI
0x3133d0 - 0x3134b2 CFMPriv_SpeechRecognition PEF binary: CFMPriv_SpeechRecognition
0x313530 - 0x313603 CFMPriv_CarbonCore PEF binary: CFMPriv_CarbonCore
0x313680 - 0x313753 CFMPriv_OSServices PEF binary: CFMPriv_OSServices
0x313830 - 0x3138f2 CFMPriv_AE PEF binary: CFMPriv_AE
0x313900 - 0x3139c5 CFMPriv_ATS PEF binary: CFMPriv_ATS
0x313a40 - 0x313b17 CFMPriv_ColorSync PEF binary: CFMPriv_ColorSync
0x313ba0 - 0x313c83 CFMPriv_FindByContent PEF binary: CFMPriv_FindByContent
0x313d00 - 0x313dda CFMPriv_HIServices PEF binary: CFMPriv_HIServices
0x313e50 - 0x313f30 CFMPriv_LangAnalysis PEF binary: CFMPriv_LangAnalysis
0x313fc0 - 0x3140a6 CFMPriv_LaunchServices PEF binary: CFMPriv_LaunchServices
0x314180 - 0x314257 CFMPriv_PrintCore PEF binary: CFMPriv_PrintCore
0x314260 - 0x314322 CFMPriv_QD PEF binary: CFMPriv_QD
0x314420 - 0x314509 CFMPriv_SpeechSynthesis PEF binary: CFMPriv_SpeechSynthesis
0x405000 - 0x443dac GSCppRuntimeLib PEF binary: GSCppRuntimeLib
0x444000 - 0x50bf3b GSRootLib PEF binary: GSRootLib
0x50c000 - 0x5aa91d InputOutputLib PEF binary: InputOutputLib
0x5ab000 - 0x68e19a TextEngineLib PEF binary: TextEngineLib
0x68f000 - 0x6d111a UCLib PEF binary: UCLib
0x6d2000 - 0x7816e8 GeometryLib PEF binary: GeometryLib
0x782000 - 0x7cb986 VBUtilsLib PEF binary: VBUtilsLib
0x7cc000 - 0x7ff18a AttributeManagerLib PEF binary: AttributeManagerLib
0x1008000 - 0x13da59a DGLib PEF binary: DGLib
0x13db000 - 0x1519d38 UDLib PEF binary: UDLib
0x151a000 - 0x1570c07 VBAttributesLib PEF binary: VBAttributesLib
0x1571000 - 0x159e3b4 GSUtilsLib PEF binary: GSUtilsLib
0x159f000 - 0x168c4c5 GDLLib PEF binary: GDLLib
0x168d000 - 0x1702f04 LibraryManagerLib PEF binary: LibraryManagerLib
0x1703000 - 0x17ce9b3 ElementManagerLib PEF binary: ElementManagerLib
0x17cf000 - 0x17ecf81 VBElemDialogsLib PEF binary: VBElemDialogsLib
0x17ed000 - 0x17f6ae9 GSQuickTimeLib PEF binary: GSQuickTimeLib
0x17f7000 - 0x17fdbeb PixMapIOLib PEF binary: PixMapIOLib
0x17fe000 - 0x17fead4 ArchiCADResourcesLib PEF binary: ArchiCADResourcesLib
0x17ff000 - 0x17ffad4 ArchiCADHelpLib PEF binary: ArchiCADHelpLib
0x2008000 - 0x338b457 ArchiCAD PEF binary: ArchiCAD
0x338c000 - 0x35b6869 VBElementsLib PEF binary: VBElementsLib
0x35b7000 - 0x38f973a GSModelerLib PEF binary: GSModelerLib
0x38fa000 - 0x3965377 ModelerGraphicsLib PEF binary: ModelerGraphicsLib
0x3966000 - 0x398f73f AddOnManagerLib PEF binary: AddOnManagerLib
0x3990000 - 0x3a1b234 GSDisplayLib PEF binary: GSDisplayLib
0x3a1c000 - 0x3a3acbb GDLParamUILib PEF binary: GDLParamUILib
0x3a3b000 - 0x3abe73f VBAttrDialogsLib PEF binary: VBAttrDialogsLib
0x3abf000 - 0x3b54549 JACKLib PEF binary: JACKLib
0x3b55000 - 0x3cff1f5 QELib PEF binary: QELib
0x3d00000 - 0x3d0481b FTPUploaderSupportLib PEF binary: FTPUploaderSupportLib
0x3d05000 - 0x3e977dc GSXMLLib PEF binary: GSXMLLib
0x3e98000 - 0x3e9b7dc GSXMLUtilsLib PEF binary: GSXMLUtilsLib
0x3e9c000 - 0x3ea8014 GSZLibLib PEF binary: GSZLibLib
0x3ea9000 - 0x3ebaa09 OSXFrameworksLib PEF binary: OSXFrameworksLib
0x3ebb000 - 0x3ec3171 OpenGLLibrarypwpc PEF binary: OpenGLLibrarypwpc
0x3ec3180 - 0x3ec3bab OpenGLUtilitypwpc PEF binary: OpenGLUtilitypwpc
0x6e17000 - 0x6e1864a NecessaryLPs PEF binary: NecessaryLPs
0x6f52000 - 0x6f52fff com.apple.URLMount.AFPPlugin 1.1.3 /System/Library/Filesystems/URLMount/afp.URLMounter/Contents/MacOS/afp
0x7053000 - 0x706efff com.wibu.www WkMacLibX version 3.31 (3.31.0.500) /Library/Frameworks/WkMacLibX.framework/WkMacLibX
0x7dc4000 - 0x7dd2fff com.apple.iokit.IOUSBLib 2.2.5 /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib
0x9087000 - 0x90c4329 SkyLight PEF binary: SkyLight
0x90e4000 - 0x910b874 Quick Layers PEF binary: Quick Layers
0x9113000 - 0x91328ce Corner Window PEF binary: Corner Window
0x9133000 - 0x915ba34 Construction Simulation PEF binary: Construction Simulation
0x917f000 - 0x9181fff com.apple.PDFImporter 1.6 (???) /System/Library/Components/PDFImporter.component/Contents/MacOS/PDFImporter
0x9618000 - 0x961a983 IFC_Common PEF binary: IFC_Common
0x9e63000 - 0x9f6c773 DXF-DWG In-Out PEF binary: DXF-DWG In-Out
0x9f6d000 - 0xa19c57d DXF_DWG_EngineLib PEF binary: DXF_DWG_EngineLib
0xa2f2000 - 0xa2f856d PEF binary:
0xa2f9000 - 0xa303ea9 PEF binary:
0xa304000 - 0xa319486 PEF binary:
0xa31a000 - 0xa321084 PEF binary:
0xa38f000 - 0xa3a5e56 Spell Check PEF binary: Spell Check
0xb617000 - 0xb618fff com.apple.aoa.halplugin 2.5.6 (2.5.6b5) /System/Library/Extensions/IOAudioFamily.kext/Contents/PlugIns/AOAHALPlugin.bundle/Contents/MacOS/AOAHALPlugin
0xba88000 - 0xbabc3cd Interior Wizard PEF binary: Interior Wizard
0xbabd000 - 0xbae4708 Accessories PEF binary: Accessories
0xbc70000 - 0xc3c6889 DWGDirectLib PEF binary: DWGDirectLib
0xc3c7000 - 0xc809be5 IFC_200 PEF binary: IFC_200
0xcac6000 - 0xcb27ff9 OpenGL Engine PEF binary: OpenGL Engine
0xd50c000 - 0xd512fff com.apple.DictionaryServiceComponent 1.0.0 /System/Library/Components/DictionaryService.component/Contents/MacOS/DictionaryService
0xde00000 - 0xde69fff com.apple.AppleIntermediateCodec 1.0.1 (124) /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
0xdea1000 - 0xdfb0fff GLEngine /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0xdfdf000 - 0xe0cffff com.apple.ATIRadeon9700GLDriver 1.4.18 (4.1. /System/Library/Extensions/ATIRadeon9700GLDriver.bundle/Contents/MacOS/ATIRadeon9700GLDriver
0xe0dd000 - 0xe0f6fff GLDriver /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLDriver.bundle/GLDriver
0xe0fc000 - 0xe117fff GLRendererFloat /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0xe345000 - 0xe3befff com.apple.applepixletvideo 1.2.5 (1.2d5) /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
0x12008000 - 0x12041fff com.apple.audio.SoundManager.Components 3.9.1 /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
0x8fd50000 - 0x8fd8dfff com.apple.QuickTimeFireWireDV.component 7.1.1 /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
0x8fe00000 - 0x8fe51fff dyld 44.4 /usr/lib/dyld
0x90000000 - 0x901bbfff libSystem.B.dylib /usr/lib/libSystem.B.dylib
0x90213000 - 0x90218fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
0x9021a000 - 0x9026dfff com.apple.CoreText 1.0.1 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x9029a000 - 0x9034bfff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x9037a000 - 0x90734fff com.apple.CoreGraphics 1.258.30 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x907c1000 - 0x9089afff com.apple.CoreFoundation 6.4.6 (368.27) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x908e3000 - 0x908e3fff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x908e5000 - 0x909e7fff libicucore.A.dylib /usr/lib/libicucore.A.dylib
0x90a41000 - 0x90ac5fff libobjc.A.dylib /usr/lib/libobjc.A.dylib
0x90aef000 - 0x90b5dfff com.apple.framework.IOKit 1.4.1 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90b74000 - 0x90b86fff libauto.dylib /usr/lib/libauto.dylib
0x90b8d000 - 0x90e65fff com.apple.CoreServices.CarbonCore 681.3 (671.2) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x90ecb000 - 0x90f4bfff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x90f95000 - 0x90fd6fff com.apple.CFNetwork 129.16 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x90feb000 - 0x91003fff com.apple.WebServices 1.1.2 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
0x91013000 - 0x91094fff com.apple.SearchKit 1.0.5 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x910da000 - 0x91104fff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x91115000 - 0x91123fff libz.1.dylib /usr/lib/libz.1.dylib
0x91126000 - 0x912e9fff com.apple.security 4.3 (25966) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x913ec000 - 0x913f5fff com.apple.DiskArbitration 2.1 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x913fc000 - 0x91423fff com.apple.SystemConfiguration 1.8.2 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x91436000 - 0x91441fff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
0x91446000 - 0x91467fff libmx.A.dylib /usr/lib/libmx.A.dylib
0x9146d000 - 0x91475fff libbsm.dylib /usr/lib/libbsm.dylib
0x91479000 - 0x914f4fff com.apple.audio.CoreAudio 3.0.3 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x91531000 - 0x91531fff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x91533000 - 0x9156bfff com.apple.AE 1.5 (297) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x91586000 - 0x91653fff com.apple.ColorSync 4.4.4 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x916a8000 - 0x91739fff com.apple.print.framework.PrintCore 4.5 (177.10) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x91780000 - 0x91837fff com.apple.QD 3.8.20 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x91874000 - 0x918d2fff com.apple.HIServices 1.5.1 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x91900000 - 0x91924fff com.apple.LangAnalysis 1.6.1 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x91938000 - 0x9195dfff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
0x91970000 - 0x919b2fff com.apple.LaunchServices 178 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x919ce000 - 0x919e2fff com.apple.speech.synthesis.framework 3.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x919f0000 - 0x91a2ffff com.apple.ImageIO.framework 1.4.6 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x91a45000 - 0x91b0dfff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
0x91b5b000 - 0x91b70fff libcups.2.dylib /usr/lib/libcups.2.dylib
0x91b75000 - 0x91b92fff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x91b97000 - 0x91c06fff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x91c1d000 - 0x91c21fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x91c23000 - 0x91c6afff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
0x91c6f000 - 0x91cacfff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x91cb3000 - 0x91cccfff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x91cd1000 - 0x91cd4fff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x91cd6000 - 0x91cd6fff com.apple.Accelerate 1.2.1 (Accelerate 1.2.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x91cd8000 - 0x91db8fff com.apple.vImage 2.3 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x91dc0000 - 0x91ddffff com.apple.Accelerate.vecLib 3.2.1 (vecLib 3.2.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x91e4b000 - 0x91eb9fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x91ec4000 - 0x91f58fff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x91f72000 - 0x924fafff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x9252d000 - 0x92858fff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x92888000 - 0x92910fff com.apple.DesktopServices 1.3.3 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x92951000 - 0x92b7cfff com.apple.Foundation 6.4.5 (567.26) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x92c9a000 - 0x92d78fff libxml2.2.dylib /usr/lib/libxml2.2.dylib
0x92d98000 - 0x92e86fff libiconv.2.dylib /usr/lib/libiconv.2.dylib
0x92e89000 - 0x92e93fff com.apple.framework.AppleTalk 1.2.0 (???) /System/Library/Frameworks/AppleTalk.framework/Versions/A/AppleTalk
0x92e98000 - 0x92eb6fff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x92ec1000 - 0x92f1bfff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92f39000 - 0x92f39fff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92f3b000 - 0x92f4ffff com.apple.ImageCapture 3.0 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x92f67000 - 0x92f77fff com.apple.speech.recognition.framework 3.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x92f83000 - 0x92f98fff com.apple.securityhi 2.0 (203) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x92faa000 - 0x93031fff com.apple.ink.framework 101.2 (69) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x93045000 - 0x93050fff com.apple.help 1.0.3 (32) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x9305a000 - 0x93087fff com.apple.openscripting 1.2.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x930a1000 - 0x930b1fff com.apple.print.framework.Print 5.0 (190.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x930bd000 - 0x93123fff com.apple.htmlrendering 1.1.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x93154000 - 0x931a3fff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x931d1000 - 0x931eefff com.apple.audio.SoundManager 3.9 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x93200000 - 0x9320dfff com.apple.CommonPanels 1.2.2 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x93216000 - 0x93523fff com.apple.HIToolbox 1.4.6 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x93672000 - 0x9367efff com.apple.opengl 1.4.7 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x94160000 - 0x9422afff com.apple.audio.toolbox.AudioToolbox 1.4.1 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x9427e000 - 0x9427efff com.apple.audio.units.AudioUnit 1.4 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x94280000 - 0x94434fff com.apple.QuartzCore 1.4.7 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x944cc000 - 0x9451cfff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x946bf000 - 0x946cefff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x946d6000 - 0x946e2fff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x94728000 - 0x94740fff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x94747000 - 0x949fbfff com.apple.QuickTime 7.1.1 /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x94abf000 - 0x94b30fff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
0x94f03000 - 0x94f20fff libresolv.9.dylib /usr/lib/libresolv.9.dylib
0x95425000 - 0x95553fff edu.mit.Kerberos 5.5.23 /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x95f87000 - 0x95f8cfff com.apple.URLMount 2.1.3 /System/Library/PrivateFrameworks/URLMount.framework/URLMount
0x9646b000 - 0x9646cfff libCyrillicConverter.dylib /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
0x9646e000 - 0x9646ffff libGreekConverter.dylib /System/Library/CoreServices/Encodings/libGreekConverter.dylib
0x96474000 - 0x9648afff libJapaneseConverter.dylib /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0x9648c000 - 0x964acfff libKoreanConverter.dylib /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0x964ae000 - 0x964b0fff libLatin2Converter.dylib /System/Library/CoreServices/Encodings/libLatin2Converter.dylib
0x964b2000 - 0x964b3fff libLatin5Converter.dylib /System/Library/CoreServices/Encodings/libLatin5Converter.dylib
0x964ba000 - 0x964c8fff libSimplifiedChineseConverter.dylib /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
0x964ca000 - 0x964cbfff libSymbolConverter.dylib /System/Library/CoreServices/Encodings/libSymbolConverter.dylib
0x964d0000 - 0x964e3fff libTraditionalChineseConverter.dylib /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
0x96f09000 - 0x96f28fff com.apple.vecLib 3.2.1 (vecLib 3.2.1) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x9763f000 - 0x97700fff libGLProgrammability.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x9772b000 - 0x9772cfff libGLSystem.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLSystem.dylib
0x9772e000 - 0x9773bfff com.apple.agl 2.5.6 (AGL-2.5.6) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x97aa4000 - 0x97ae2fff com.apple.AppleShareClientCore 1.5.1 /System/Library/Frameworks/AppleShareClientCore.framework/Versions/A/AppleShareClientCore
0x98bbf000 - 0x99595fff com.apple.QuickTimeComponents.component 7.1.1 /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x997ab000 - 0x997aefff com.apple.QuickTimeH264.component 7.1.1 /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
0x999ba000 - 0x99a78fff com.apple.QuickTimeMPEG4.component 7.1.1 /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
0x9a36e000 - 0x9a38cfff com.apple.OpenTransport 2.0 /System/Library/PrivateFrameworks/OpenTransport.framework/OpenTransport
0x9a407000 - 0x9a408fff com.apple.iokit.dvcomponentglue 1.7.9 /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
0x9a460000 - 0x9a4c4fff com.apple.urlaccess 1.1 (21.0) /System/Library/PrivateFrameworks/URLAccess.framework/Versions/A/URLAccess
Model: PowerMac12,1, BootROM 5.2.6f1, 1 processors, PowerPC G5 (3.1), 2.1 GHz, 1.5 GB
Graphics: ATI Radeon X600 XT, ATY,RV380, PCI, 128 MB
Memory Module: DIMM0/BUILT-IN, 512 MB, built-in, built-in
Memory Module: DIMM1/J6700, 1 GB, DDR2 SDRAM, PC2-4200U-444
AirPort: AirPort Extreme, 404.2 (3.90.34.0.p16)
Bluetooth: Version 1.7.3f4, 2 service, 0 devices, 1 incoming serial ports
Network Service: Built-in Ethernet, Ethernet, en0
PCI Card: ATY,RV380, Display, PCI-E
Serial ATA Device: WDC WD2500JS-40MVB1, 232.89 GB
Parallel ATA Device: MATSHITADVD-R UJ-846,
USB Device: Hub, , Up to 480 Mb/sec, 500 mA
USB Device: Built-in iSight, Micron, Up to 480 Mb/sec, 500 mA
USB Device: IR Receiver, Apple Computer, Inc., Up to 12 Mb/sec, 500 mA
USB Device: USB Flash Memory, , Up to 480 Mb/sec, 500 mA
USB Device: Hub in Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 500 mA
USB Device: USB-PS/2 Mouse M-BA47, Logitech, Up to 1.5 Mb/sec, 100 mA
USB Device: Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 250 mA
USB Device: Bluetooth HCI, , Up to 12 Mb/sec, 500 mA
USB Device: WIBU-BOX/U, WIBU-SYSTEMS AG, www.wibu.com, Up to 1.5 Mb/sec, 500 mA
Report Version: 4
Command: ArchiCAD
PID: 270
Thread: 0
Thread 0 Crashed:
Thread 1:
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
