2011-07-17 10:44 PM - last edited on 2023-05-23 02:49 PM by Rubia Torres
2011-07-17 11:13 PM
2011-07-17 11:30 PM
2011-07-18 11:05 AM
2011-07-18 05:32 PM
laszlonagy wrote:How do I make the single plane part of the complex roof?
I think here you should make that single plane part of the Complex Roof it connects to.
See how the Pivot Lines of the Complex Roof now go and how two roof planes of that right part are set to Gable.
2011-07-18 07:31 PM
2011-07-19 02:24 AM
laszlonagy wrote:Thank Laszlo, I was able to get it to this extent but have hard time extending the roof in the middle to the roof to the left to get the same effect you show. Could you guide me further?
See the image I posted.
Note the Pivot Lines. This is what I have drawn. The Multi-plane Roof was generated.
Then not the two sides where it says: gable with zero overhang.
Click each of those edges, choose the Gable radio button (which in effect will erase that roof plane), and set its overhang value to zero.
This was my solution.
2011-07-19 03:30 AM
2011-07-19 03:39 AM
s2art wrote:Editing the polyroof would be just too cumbersome for doing an opration which in AC14 use to take few second; he must have extended the roof on the right to left a lot faster, just do not know how ?
I think Laszlo is suggesting you edit the polyroof on the left, adding geometry to it to replace the single roof.
2011-07-19 04:22 AM
Joseph wrote:Pet palette / magic wand takes no time at all.s2art wrote:Editing the polyroof would be just too cumbersome for doing an opration which in AC14 use to take few second; he must have extended the roof on the right to left a lot faster, just do not know how ?
