‎2005-12-09
08:52 AM
‎2023-05-25
05:15 PM
Rubia Torres
‎2005-12-09 12:41 PM
Srinivas wrote:Objects don't automatically clean up to anything, so the intersection priority is not a factor. For the beam to cut your object-column, you need solid element ops. Unfortunately, I don't think object volume is correctly calculated with the object has been cut by SEO.
I created a tapered column with the profiler tool, my beams were passing through this column. So i want to make sure the intersection priority is made to the column so that my volumes were exact.
Srinivas wrote:Meshes, too, don't respond to intersection priorities, and they are not automatically cut by beams. You would need to do an SEO subtraction there too, but with a mesh, the volume is calculated correctly, considering the subtraction.
or is it possible to create an intersection priority when i create the same tapered column with the mesh tool?
