Intersection and priorities in complex profiles
I have been trying to get some mouldings to intersect properly but im having trouble with "T" shaped intersections.
Do comlex profiles behave the same way as composite walls regarding skin priorities?
I made a little test profile just fot the sake of example, see the picture below.
-the reference lines are touching
-the brick skin priority is set to 0
-the brown skin priority is set to 6
And still, the skins are not intersecting properly at the "T" junction.
I searched the forums for a similar situation but couldnt find it.
Is there something I missed?
23 REPLIES 23
See attached screenshot: for the priorities that you set up in the profile to be considered, you must check the box for 'Enable Skin Priorities'.
(Generally, for composites and profiles, I have all boxes checked so that the composite or profile definition defines all attributes, thus making the definition a 'style' or 'type' that can be edited in one place and changed everywhere.)
One of the forum moderators
In the process of reproducing your screenshot, I discovered an unpleasant situation in 11 (have not tested in 12) regarding the 'Ending Contour' pen for the complex wall profile.
See the attached screenshot. The full ends show the heavy black line, but it also shows up as a short segment on one side of one skin of a wrapped corner. Pretty bizarre. Anybody have an idea on that one?
This gets weirder: in 12, the short end segments are still there, but on opposite sides of the corner. But, in 12, I cannot seem to control the weight of the contour cut by the floor plan cut plane.
No matter what pen I assign, the outside contour lines are always the same weight. The teal/blue pen is hairline (0 mm) and the red is 1.00 mm, but they appear the same in the attached screenshot. The pen color is clearly being taken from the Profile Editor, but I have no idea where the weight is coming from...?
Thank you Karl for the quick reply.
I also had that box checked for my profiles ( in fact it the 1st thing I checked ). I suspect that you are using a "composite wall" rather than a "complex profile" (the later being accessed in the profile manager).
The quick example I posted might be what confused you.
in fact the mouldings are more like an extrusion.
here is a picture of how I worked my way around the problem. I used two half profiles with reference lines on the "outer edge" so they dont overlap.
top picture is the first unworking model, bottom one is the workaround.
Cheers!
EDIT: seems like we posted at the same time ( and I was wrong, you ARE using the complex profile after all)
And thats a weird behavior you have there with those endlines
I did not need any workaround to get the complex profile to intersect correctly. If your original profile is still not intersecting, select just those pieces and do a 'save selection as module' and post a zip of the module.
Hello.
I have read this post a few times, but somehow don't think I'm getting it just yet.
Based on Arthur's last example, I may be trying to do something that is not possible in C.P. because the last 2d "workaround" looks different than what I'm after.
So attached is what I've been trying to do, and hopefully someone can let me know if it is even possible in C.P..
At least at that point, I will struggle on!
Bier
There is no workaround, Bier. It just works - as seen in my screenshots.
In that case, I had a profile that had two tall 'curbs' on either side of a 'roadway'. I just repeated it with a new profile along the lines of your screenshot where you just circled the tops of the 'curbs' - suggesting a full slab below. With the 'roadway' at priority 6 and the 'curbs' at priority 0, the correct result is seen.
If you do not see all of the contours at all - then it is a Floor Plan Cut Plane height issue. If they intersect incorrectly, then make sure that the fills are different, the priorities are set similar to above, and that the tool settings are NOT over-riding any of the profile settings. 😉
Rod Jurich
Bier wrote:
Hello.
No need to struggle Bier, this may help.
Celia's Tip
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Link
Karl, are you assigning the Ending Contours in the Profile? Of course all the Structure's Settings must be applied in the Wall Settings.
Link.
