Intersection line between same composites
I am newie in Archicad. I have a very simple question. I am drawing some interior walls with gypsy boards. On each intersection one of the walls finish against the other wall, normally perpendicular. So regardless they have the same materials I need to keep the intersection line, because in real constructions the materials do not merge, this is not concrete. I read that the only solutions is to change to different layer with different intersection settings or using different fake materials, or using different cutting fills for each material.
This make the drawing unnecessary complex, is there any other option that works and do not brings to the drawing, new layers, new materials,...
Erwin Edel
You will need two different materials and two different composites, but I would just draw a line there or actually I wouldn't, but I would not be trying to show this amount of detail and explain all the billable hours
It sounds to me like you are at 1:5 scale level of detail. At this level of detail I just make 2D detail drawings that are not connected to my model.
Floor plans and sections and such rarely go beyond 1:50 scale for me, where you cannot really tell this kind of detail when printed out.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
