Invisible Texture Problem
I have created an invisible texture for use on some of my AC17 complex profiles to remove things that should not be seen.
The problem is that I get the attached problem, it is invisible, but so is anything you should see when looking in 3d etc.
In section it looks fine!
any help welcome, cheers
I am using AC 17 with the latest hotfix installed on a MAC.
Sorry, image attached.
Transparent materials in 17 will make the entire composite or complex profile transparent in 3D.
It will work as expected in 18.
I don't know that this will ever be fixed in 17.
Cheers Barry, at least i know its not me doing something wrong!
