Is it possible create zones in 3D document?
Esdras Santos
Is it possible create zones in 3D documents?
Esdras Santos | architect
www.esdrasantos.com.br
AC 16 64 bits BR - PC Core i7 2.60GHz 8GB - win10
No, it is not possible, you can select construction elements and edit their settings in the Info Box or their Settings Dialog, but you cannot create new geometry or modify geometry graphically in the 3D Document Viewpoint.
You can use all your annotation tools like dimensions, texts and labels though.
Think of the 3D Document Viewpoint as a documenting Viewpoint rather than an element creation or modeling Viewpoint.
Esdras Santos
Ok, thank you!
I was trying to get some areas for approval plans, without section or elevation marks...
Regards,
