Is it possible to show cladding outerlines in 3D&elevations?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2015-12-15
11:42 AM
2023-05-24
08:44 AM
Rubia Torres
Task: I have some cladding on my facade, which I want to make visible by showing the separation between the one panel and the other. The only way I can see doing it, is to create a gap between them. Is it possible to make it without doing it? Because now it looks like a one plain wall...Will really appreciate some advice.
Check also the screenshot file.
Thank you.
Lia
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-12-15 01:35 PM
For vertical joins you can place small columns and use a Solid Element Operation to cut them from the wall (and hide the layer the columns are on).
You could do this with beams also for the horizontal joins.
Or you could make up a frame from a curtain wall and use that in a SEO so you can do the horizontal and vertical all in one go. It may also be easier to manipulate the curtain wall scheme if your panel sizes change.
Or you can use a wall accessory to do it.
The advantage of this is it will always match your wall and will allow for door and window openings.
You need to install the accessories add-on (downloads in the HELP menu) and then find an accessory object. I don't think the default Graphisoft accessories will do what you want.
But maybe CadImage have something and there was one made for James Hardie products that may be on there website (although that could just be an Australian thing).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-12-15 02:31 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-12-15 03:06 PM
When two panels are the same material , AC heals them together so they look like one piece. But if you use separate materials, even though they have the same surface and cut fills and whatever, then AC won't heal them and will draw their contour lines.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-12-15 03:23 PM
mbeam wrote:This is true but means you must model each panel as a separate wall.
All fine but it becomes difficult when you want to place doors and windows in the wall - they will only belong to one panel and won't cut the others.
So you have to place empty openings in the other panels to cut the holes.
Then it gets a bit messy if you need to move or resize a door/window.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-12-15 04:07 PM
Is that even possible suing curtain walls?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-12-15 04:33 PM
But they have a 'scheme' which is the basic repeating pattern.
But then you should be able to add or delete frames wherever you want.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-12-15 05:16 PM
