Is it possible?
to place archicad drawing in to another archicad drawing same for example as you placing as external content DWG files
thanks
2 Replies 2
rocorona
Yes. You are talking about Modules.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
yes.
place a drawing on the layout using the 'drawing tool' and choose to link to external source, browse, select your other archicad file and chose the view you 'd like to place. You must have saved a view in the other archicad file first (just as you would normaly to place on a layout)
that is if you mean an archicad drawing on a layout.
if you mean to place an archicad drawing on a plan view, then use hotlink (same way you x-ref), refer to the manual on how to do that.
hth
