Is saving as *.2DL still available?
i run on version 9, coming across a frustrating problem with saving out as .2dl file.
in previous versions of archiad, within the 3d window, you could "save as" *.2dl. this creates a new file with the extension .2dl, which turns all the materials and especially the shadows into fills. which you can then open and edit in floor plan.
if someone knows, could you please tell me whether this is available anymore? it seems like it is, because when you go open, it is available to open. if so, how is it done? are there any special proccesses to make *.2dl file extension available when you go "save as" in the 3d window?
thanks.
Rafal SLEK
http://archicad-talk.graphisoft.com/viewtopic.php?p=69515#69515
watch your second post
Best
Rafał
//Archicad since 4.1 version
//MacBook Pro Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/macOS 13.6
//Razer Intel i9/2.5GHz/32GB/Nvidia RTX 3080/Windows 11 Pro
//ArchiCAD 28/Twinmotion 2024
YES
USE INTERNAL ENGINE IN 3D WINDOW SETTING (analitic method). YOU WILL SEE 2DL FORMAT İN SAVE AS
Yes. after playing around with the settings for quite a while i discovered this. but that was the exact, and most accurate answer i was looking for.
use internal engine!
thank you.
