Is there a grid of Revit in Archicad?
LeeJaeYoung
What do you see in the 3D view? ^^
Discover BIM with Archicad in 7 Minutes - YouTube
AC27 on window 11
7 REPLIES 7
Your question is not clear.  What is it that you need?
AC 28 USA and earlier   •   macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
One of the forum moderators
What looks like a grid below?
I couldn't draw lines in the Archicad in 3D.
I solved it with morph.
The text was also solved with 3D text.
AC27 on window 11
Miha_M
Grid lines? Those are Grid elements and they are present in Archicad since a long time. You can find them (individually or in a Grid System) in the Grid Tool.
| Archicad 4.55 - 27
sorry.
I misunderstood and told the story.
I guess I was thinking that grid etc cannot be used in 3D.
In other words, I was thinking of Revit's grid and Archicad's grid tool in reverse. Revit misunderstood that the grid doesn't appear in 3d. sorry. ㅠㅠ
AC27 on window 11
thank you so much
AC27 on window 11
show as a line
thank you ^^
However, I misunderstood REVIT and uploaded it.
The current Grid is a bit inconvenient in my practice.
Normally, you should be able to drag the grid by element, but Archicad doesn't seem to support dragging by element yet. It's only possible in 3D.
In Revit, 90 degree bends, which I mainly use, are possible. It seems that Archicad needs to be edited with GDL.
Usually, it is expressed as follows, so I do not use Grid in Revit and Archicad.
AC27 on window 11
