Is there a shortcut key for "Rotate 90 degrees"...?
... rather than having to use the lengthy (by comparison) "Rotate tool > select origin > initial angle > final angle" process.
Ideally, I'd like "Rotate 90 left" and "Rotate 90 right" keystrokes.
Has anyone managed to do this?
5 REPLIES 5
Ctrl-E is pretty as close to this as I would want to get since you need to indicate the center point and direction of rotation anyway.
I find myself moving doing copy > rotate 90 > move processes with elements often, so the origin of rotation doesn't often enough matter in this case, because it's followed with a move operation.
vistasp
You could combine the first two operations by rotating a copy with
Ctrl+Shift+E
HTH
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
There is an existing wish here if you would like to vote -
http://archicad-talk.graphisoft.com/viewtopic.php?t=28816
I still think my idea of using the arrow keys is a good one!
Arcadia
Yes I want the same thing. My old 2D software could rotate stuff left or right 90 deg by using the plus and minus keys on the keypad by a configurable amount (ie 90 deg or 45 deg). Soooo much quicker as most of the time when you want to rotate something it is by 90 deg.
V12-V27, PC: Ryzen 9 3950X, 64g RAM, RTX5000, Win 11
