2013-08-20
02:03 AM
2023-05-24
07:28 PM
Rubia Torres
2013-08-21 12:54 PM
2013-08-21 08:01 PM
Marky wrote:
Options -> Work Environment -> Guide Lines -> Increments of Guide Line:
2013-08-21 08:13 PM
2013-08-21 08:17 PM
2013-08-21 08:20 PM
2013-08-22 02:31 PM
Jonathan wrote:If the mid point does not show up, try the Special Snap Point constraint to create it on the fly.
When trying to find the center of the morph element that I wanted to rotate into an inclined barrel vault the half point mark did not appear and the protractor would only indicate a horizontal rotation when placed on the bottom edge of the morph.
Jonathan wrote:During the rotation edit, you can right-click to get the context menu to get to the Editing Plane > Pick Plane command to select the plane of rotation.
We should be able to see the half point and the protractor should cycle through the x,y & z axes when placing the curser on that point.
