How can I disable shadowing in the 3D window?
So, I've done some hunting and simply can't find anyone mentioning this before. How can I disable all shadowing in the 3D window? If I use the internal engine, it gives me the desired effect but chugs hard everytime I move the camera. Open GL runs fine but my objects end up bleeding into one another on their dark sides. All I want is to disable shadows and leave contour lines enabled. Any help?
Mac 10.6.8, ArchiCAD 16
Eduardo Rolon
Right Click in the 3D Window and select settings
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
There you can turn shadows Off
AC29 US/INT -> AC08
another Moderator
