Isolate Tool
Llian
is there an isolate tool for on object, element, etc ?
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
If you want to Isolate elements by their Layer, then you can use the Quick Layers Palette.
Select the elements to keep, then click the Hide Other Elements' Layers on the Quick Layers Palette.
Layers of selected elements will be kept visible, all other Layers will be hidden.
Llian,
Could you be a little more descriptive in your purpose of an "Isolate tool" so that we may be able to better help you
NCornia
Graphisoft Alumni
Graphisoft Alumni
To isolate an element/selection in 3D: select the object(s)/element(s), right click and click "Show Selection/Marquee in 3D". Windows shortcut: F5. Mac shortcut: F4 This is a great way to build objects inside a project as well. Create the object with building tools, isolate it and save as an object.
To isolate something in plan view you would have to place an obejct on its own layer and turn all others off.
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
